TUCQUALA
Nov 22, 2015Explorer
Consider running the hose to a tee in the FW tank vent line. Then you would not have to go outside as I see it!!! Should work ok esp if you use a running tee, one that would have an angle to one leg pointing toward the tank. Just turn on your new valve, and send the hot water down the vent tube.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
