RoyB wrote:
AFter I saw this post I went looking at specs and seems like the standard is around 1800WATT which is 15AMPS @ 120VAC... Thats a pretty good draw haha...
My 2KW Honda generator would not run this with both burners going...
Why wouldn't your gen handle it? That is 2,000 watts.
The units I have seen and researched are all the same 1800 watt max so they can be used in a standard home 15amp circuit. The problem with the 1800 watt double is that you can't use both burners at over half heat. 900 watt each. Or 1 burner at full heat (1800 watts). Correct me if I'm wrong.
