rhagfo
Nov 10, 2019Explorer III
Well we went with Vinyl plank flooring snap lock (Listed as NOT recommend for RV). I found this easy to work with as it cuts with a sharp utility knife.
I tacked the first row so I had some solid to work from. Got our at HD needed about $200 worth to do living room and kitchen. Other than the 1st row the floor is floating.
Prep work, removed end table between chair and bench.
Working around sink peninsula, I needed to work backwards on the other side, went together well.
This is where needed to work backwards, the snap lock worked fine working back into this space.
This is the finished floor, with out the trim.
Trimed out, I don't like heavy trim, use 1/4" X 1" oak screen door trim, with one edge cut square.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
