profdant139's avatar
profdant139
Explorer II
Dec 16, 2018
Is your spare tire mounted on little tee nuts? Check it out
My trailer’s spare tire mount is on the back wall of the trailer. I was thinking about mounting a small one-gallon gas can (for my generator) on top of the spare. (That project will be described in a separate post, coming soon.) But before I began the gas can project, I took a good hard look at the spare tire mount.
I removed the spare and realized that all four of the bolts holding the mount onto the back wall were a little loose – yikes! Worse yet, when I tried to tighten them, they did not tighten.
It turns out that the tee nuts inside the back wall of the trailer were rotating as I tried to tighten the bolts – the little prongs anchoring the tee nuts had bent.
Clearly, the tee nuts were not adequate for the load of the spare tire, especially given the vibration and shock caused by the spare tire on rough roads. This is what the tee nuts looked like – tiny and inadequate:
Click For Full-Size Image.
So instead of the original quarter inch steel bolts, I put in 3/8 inch stainless steel bolts. Instead of tee nuts, I added a thick piece of steel bar and used heavy duty lock washers and nuts:
Now the load will be distributed over a wider area of the back wall, reducing the “force per square inch” caused by the weight and vibration of the spare tire. And you can bet that I will check these bolts and nuts every so often, just to make darn sure that everything is secure.
  • That's a good repair. Your profile says "modified for off road". I think I would find a new location for your spare. I would hate to see that entire back wall crumble or crack from one big jolt. Maybe I'm just too cautious.
  • Looks good and should hold a lot better than the junk they had installed to mount it.
  • I went out to YouTube and pulled up a couple videos on your camper to help understand how that tire is mounted to your camper. When I saw the videos I undrstood .... yikes! I thought mounting spare tires on bumper was daunting, but seeing yours is just hanging on the wall, dangling with no other support .... yikes!
    We each do it our own way, but I removed my spare tire from my previous travel trailer bumper mounts and carried them in the back of the pick-up truck bed and kept the weight off the bumper. I did this with all 3 of my different travel trailers.
    But your's looks even weaker than that. Nice fix you did there. Hopefully this will work well for you. Yes, check often.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Dec 11, 2017
