Cummins12V98's avatar
Cummins12V98
Explorer III
Oct 08, 2016
Junk Washer out Quality Washer in!
Was tired if the Chinese Made Whirlpool not discharging all the water at the end of cycle. It would work for a while then not. Called Whirlpool thew only suggested service and was out of warranty. I decided it was not worth throwing at least $3-400 out the window to fix it especially after doing research on the net about the problem. I cleaned the filter but it was already clean.
Doing research the Bosch 500 series kept coming up highly rated. It's actually 220V 20A. My dryer is 220V and if it were a Bosch the washer would plug right into the dryer. My dryer and new washer use 26A combined so it was a no brainer to tap the dryer junction box as shown.
Oh always read directions! I did not take out the shipping bolt/plugs on the back, it was like a 7.0 earthquake with the first load. THEN I read the detections. It washes MUCH better and runs MUCH smoother than the old one!
Oh I found another POS DRV item, the dryer 4 sq metal box was NOT grounded!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
