etrippe
Jan 12, 2016Explorer
kitchen countertop removal
Time for a new top and sink. Any thoughts on removal of the existing countertop? Will it come out with damage to the drawer fronts and cabinet walls? Is it simply screwed in from below?
myredracer wrote:scotty46 wrote:
If properly prepared, formica/laminate can be glued right on top of another stable formica/laminate surface. I have done it before with good results. No need to tear up the cabinet tops.
Wouldn't that not work because of the existing stove opening? Seems to me raising the height of the top would leave a gap between the bottom of stove and cabinet.
Could perhaps fill in the gap with matching wood (if available) but if his counter can be easily pulled out (which it now seems) that's probably the easier way to go.
