bamagirl
Jun 19, 2013Explorer
Kool Seal
Does anyone know where I can buy Kool Seal for Rubber Roof. I want the one that is specifically for RVs. Lowes apparently does not carry Kool Seal at all anymore.
ryhed wrote:
Gdetrailer
Nowhere in the product data sheet does it recommend using it over fiberglass. It needs sanded surface prep minimum for proper adhesion and also requires a primer and two coats of finish in a cross hatched application. I could only assume your preparation technique being a specialty coating applicator for many years, but do tell. Just read the pds.
To the op, while it probably works, I would pick something else, then again I do industrial coatings and those products may not be readily available to you. I used roofmate and added microballoons into it for thermal insulation. Here is a product at lowes that has microballons,http://www.lowes.com/pd_354718-29-5532-1-30_4294934213__?productId=3372930&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=, but it is not intended for rv roofs but some have used it in the 700 formula, read reviews. I took two products that were compatible roofmate, epdm compatible white elastomeric coating, and microballoons purchased in the 5 gallon kit from http://www.hytechsales.com/.
bamagirl wrote:Can't you buy it online?
I have tried Googling it. The stores that it tells me carries it in my area do not carry the one specifically for rubber roofs.
aarond76 wrote:
So does anyone have experience with this? Does it actually help keep it cooler in the trailer?
