DRSMPS
Jan 29, 2014Explorer
Laminate Flooring Advice
During a recent power outage at the house, I went into the TT which is stored in my yard to retrieve some flashlights and lanterns. I had the battery out of the TT as it was stored for the winter so things were dark. I made the mistake of sliding a metal toolbox out of one of my storage compartments and it cut my linoleum floor tile just in front of my kitchen cupboards.
I can't see repairing the linoleum without it looking bad. Therefore this spring, I want to replace the flooring in the main section of the TT with wood laminate. I like the look, but am curious if you can offer any advise so I don't make a mistake installing the wrong product or installing it the wrong way.
My concerns are as follows:
-How much expansion room do I leave along the walls knowing that laminate expands with temperature / humidity? While in storage the TT can get very cold or very hot.
-Am I better to use the snap together laminate with a thin underlay or is the peel and stick adhesive type better in this type of application? I'm concerned that with the bouncing of the TT while going down the road that the snap together type may not hold up.
Thanks in advance for any advise you can provide.
