- CFergusonExplorer IILooks nice.
- rhagfoExplorer IIIWell we went with Vinyl plank flooring snap lock (Listed as NOT recommend for RV). I found this easy to work with as it cuts with a sharp utility knife.
I tacked the first row so I had some solid to work from. Got our at HD needed about $200 worth to do living room and kitchen. Other than the 1st row the floor is floating.
Prep work, removed end table between chair and bench.
Working around sink peninsula, I needed to work backwards on the other side, went together well.
This is where needed to work backwards, the snap lock worked fine working back into this space.
This is the finished floor, with out the trim.
Trimed out, I don't like heavy trim, use 1/4" X 1" oak screen door trim, with one edge cut square.
- Cummins12V98Explorer IIIPersonally I would use LVT and glue it down. Simply pull a pc to replace if needed.
- BusdriverExplorer IILet it float. Had laminate floor in a previous camper fo eight years never a problem with it
- ScottGNomadLet it float and don't use glue. In something as small as an RV, you don't need to leave as large of a gap around the edge but I would still leave at least 1/8~3/16". Also, if it's snap together type, don't pound them together. Only use enough force to make them click and no more. Otherwise you will end up with tiny raised edges that look terrible in the sun.
I have seen the results of a floor not having enough room to expand and it's amazing. The middle of the floor will rise up like a giant blister. It can move furntiure and people standing on it as it expands. I've fixed bad installs but it's a pain.
You don't want to make any mistakes or do anything other than what the manufacturers suggests. - TenOCNomadNo not in a house with large rooms. The floor should float. However, in my RV I did nail (with a small brad nailer) the floor down.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
