Almot's avatar
Almot
Explorer III
Oct 08, 2017
Larger suction pipe to pump - better?
All inside tubes, inlets on the pump, and suction tube from fresh tank are 1/2". 3GPM pump, 40 PSI on the push side, self-priming up to 10ft (I think).
Now, imagine fresh tank 6ft away, sitting on the ground on seasonal camp (no city water there). If I run 3/4" suction pipe to the pump, leaving the output side unchanged 1/2" - will it be better, worse, or the same? Plumbing theory suggests suction/input 1 size bigger than output, but I have a feeling that it will not matter much on this short distance.
There is 0.5 micron sediment filter before the pump, with 3/4" outlets and 1/2" adapters, so I can have input tube either 1/2 or 3/4. Filters have been known to prefer larger input, too.
  • DrewE's avatar
    DrewE
    Explorer III
    In theory the larger pipe would have very very slightly less internal resistance to flowing water.
    In practice it makes not one bit of difference given the low flow rate and fairly short distance you're dealing with. Reducing the suction head would likely have a greater benefit (if that is possible).
    A larger filter may possibly be of some value in terms of frequency of servicing it and its tendency to choke off the flow of water. That's hard to say without investigating the specifics of your setup and water clarity and so forth. Even with that, I doubt I know enough myself to make any useful recommendations.
  • Almot's avatar
    Almot
    Explorer III
    "Better" - I meant easier on pump or better for a filter? Or - less cr-ap deposited in the tube before it gets to the filter (not really "less" cr-ap, but less notable in larger tube).
  • No change.......
    Pump inlet/outlet still 1/2"
    Pump 3 gpm/45 psi regardless
  • I had a 5.7 GPM 65 psi pump that drew from a 1/2" line in my last TT. It worked great and could provide flow to more than one faucet at a time.
    So I honesly dont think a bigger line would help especially with a smaller pump
  • Better or worse what? Pressure? Flow rate? The answer to both though, is "No." The limitation is the inlet bore on the pump as well as the internal pump "plumbing" where the water passes through the diaphragm ports and check valves. The only practical cure for that is a pump with a higher pressure/flow rate capacity.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
