springoflife
Jul 10, 2015Explorer
LED Bulb Replacement for Taillamp - Possible Snag
I intend to replace the 1157 bulbs in the rear of my camper with LED's. The 1157's aren't very bright, especially in sunlight. And when turning, the delay for when the brighter filament actually illuminates is so long, that it barely appears to blink. LED's are "instant on". (I have tried different "powered" converters, checked that my grounding is okay, etc.)
The general rule is to use LED's that are the same color as the lens -- in this case, red. So I did a lot of research, and found what I believe will cure both problems.
But it raises a new concern. The red tail lens on the left-side of the camper has a small clear spot underneath. The intent is to shine a little bit of white light downward, onto the license plate. Now that the LED bulb inside will be red, will that cause an issue? I think it will give the Plate a soft, red glow at night; which could be mistaken for not being illuminated at all. If a state trooper happens to be driving behind me, will I get pulled-over?
