Gdetrailer
Dec 19, 2014Explorer III
RoyB wrote:
It is more than just mounting lights on the rear - they have to come on only when you are in REVERSE... They also have to be DOT APPROVED LENS on the lights...
This is what happened to me here in VIRGINIA when I mounted two lights on the bottom of my OFF-ROAD POPUP trailer. These were turned ON by a separate switch inside my POPUP trailer.
Much like this GOOGLE IMAGE from the internet...
GOOGLE IMAGE...
They worked out pretty good for me...
Then I had to get my Virginia Safety Inspection a couple of months later and the first question I got was why those lights did not come on when he asked to put my truck in reverse... The inspector also said he could not find a DOT NUMBER stamped on the lens...
He made me remove the two lights before I could pass my DOT Safety Inspection.
After taking them off I just decided not to have any mounted. I could have added the 12VDC line from the center connector of the 7-way trailer connector but just decided I would go for lights on the side of the trailer.
Back in my JEEP DAYS I was always running into SAFETY INSPECTION problems with all of our lights mounted on bars and things... DOT just doesn't these lights to ever come on when driving down the public roads...
Sorry to start anything here from what I said - Just passing along what I went thru a couple years back. Take it for what ever it is worth... I can remove my comments if you guys like...
Roy Ken
Roy, I STATED that the only "rule" is rear facing WHITE LIGHTS MUST be only active while in REVERSE.. That means a MANUAL SWITCH IS A NO. NO.
Your inspection station flunked your setup BECAUSE of the MANUAL SWITCH, then they started the nitpicking from there..
Many people think they are being smart or coy about rigging up rear lights on a manual switch but as you found out it is not acceptable.
Had you done it correctly the first time they would not have hassled you.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 13, 2026
