GlennLever
Dec 23, 2014Explorer
JN_B wrote:Zede98 wrote:
Hello this is my first post
I would like to install led flood lights to the rear of my trailer with a separate rocker switch located near the battery in front of the trailer. My thought is that I will be able to flood the area I'm trying to back into.
I would like to know thoughts on the best way to install something like this... Should I run the wire under the carriage or snaking it between the roof and ceiling?
Funny how off topic everyone gets..
OP wants to install the switch and lights on the trailer. Not the switch on the truck and lights on the trailer. Or both lights & switch on the truck.
Do Trailers have to get annual DOT inspections? Pretty sure not.
And besides that having both the switch and light on the trailer make it pretty hard to activate the light while driving.
If you are worried about it, but some lights with covers, then leave the covers on until you need them. Pretty hard for DOT to argue with covers, and it will protect your lights.
Personally, I would install the lights under the trailer. It would give you a better perception of the terrain, by creating shadows which would show the dips/highs of the terrain. If you lights are on top of the trailer, you won't see the dips/highs as well..
DOT can inspect any time they want, state inspections are annual here in NY (yes a trailer has to be inspected here).
I have both the Loading/unloading lights and the switch in the trailer.
If the trailer is an enclosed car carrier and the purpose of the lights is for loading and unloading the rear gate would be down blocking lights under the trailer.
I have the unloading/loading lights on the top rear.
I put LED boat bow lights on the lower edge and on the sides of the trailer two per side. They work well as they are angled to point straight off a pointed boat bow, so on the side of the trailer they are angle out and to the rear of the trailer. I wired them to come on when the Motor Home is in reverse.
These are the lights I used. Surface mount docking lights.
If I had it to do over I would have used regular Halogen Lamp spot lights.
LED lights are bright to look at but I do not think they throw light as well as the old school filament lights.
Just my thoughts.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 13, 2026
