jims1
Dec 28, 2014Explorer
I have 6 lights on the bottom of our 5'er. 2 are mounted near the front landing gear, 2 in front of the tires aimed out at 45*, and 2 on the rear. They are all LED flood lights which light up a pretty good area.
Wiring to the back was in the grey 1" conduit with a box at the halfway point for the middle lights. I also have them switched separately- front, middle- rear. I also have the ability to turn on the rear ones from inside the truck to give a little light when backing into a spot at truck stops, and such. What I did was buy the cheapest 14g 75 or 100' extension cord I could find.and used it inside the conduit. The LED's only have a 18 watt draw.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 13, 2026
