2500_Grunt
Dec 30, 2014Explorer
If you decide to add lights back there you should install a relay if the lights are not led. Non led flood lights could draw a large enough load and over tax your truck's electrical system and /or make wires hot. I am a believer in that the ele. system was not designed to handle much more load than stock and even a small draw could throw codes and create problems. Relay's are cheap and good assurance. I have 2 Walmart 4" back up lights installed off of my TV hitch and I wired in a toggle switch right next to them so I can also use them when hooking up at night. Works great! Put them on and don't worry about LEO issues! Safer to have them than not to and have decreased visibility.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 13, 2026
