austinjenna's avatar
austinjenna
LED Strip Light Warning
I mounted the LED strip light under the awning where it attaches to the side of the trailer so we can use them if the awning is rolled up or not. They are the ones with the zillion different colors, fade, blink etc....but just a warning that you will be asked by virtually everyone on how you did it, where you bought them etc...
If you are a social person then you wont mind. My wife told me I need to print something out on where I bought them and how I did it to hand out next time LOL.
By the way they work very nicely. Originally we had string lights on the old fiver but with the new electric awning I cant really tie the awning down and worry about it at night so now I can just bring it in every night and still be able to use the lights. Plus since they are already mounted its one less thing I need to setup
  • Here is where/how I did mine:
    I bought the LED light strip from Ebay from a seller named PITALAM for $20.00.
    They are ‘5M 5050 SMD LED RGB Waterproof 300 LED Strip Light Lamp + 44Key IR Remote’ You need to make sure they are the waterproof ones for outside. It came in a 15ft roll and you can cut them shorter at every 3rd LED. There is a little mark along the strip that shows where they can be cut.
    They are12Volt powered, so either wire them directly to something off the trailer or you will need a power brick if you want to run them off a 120 outlet.
    I needed an extension for the LED strip since I ran mine down the awning arm. If you have an electric awning there is a plastic cover that pops off the arm that has the motor on it where the power cord for the awning motor runs down. I just ran mine down to the bottom of the arm so I can plug in the controller. The LED extension cord is a 2.5 meter also from Ebay from a seller named sunrisedevelopment 2011 for 6.00
    ‘2.5M extension cable connector 4pins plug for led strip lights RGB5050’
    For power I just ran some wires from the battery to where the controller would be and put a in line fuse in.
    So far its been up there about a month and the tape has held up. I cleaned the track first with rubbing alcohol before attaching the tape to it. The extension cord that runs through the awning arm and attaches to the light strip up top, I did put a glob of caulk to hold it there and then just coiled up the rest under the awning arm cover so the other end just sticks out under the awning arm. When I am setting up I plug the controller into the end sticking out a pick and the power cord in and I am good to go.
  • We have a channel in our awning tube for the lights. Don't have to take them down to roll the awning up. An extension cord runs from the outdoor plug in in one of the bays, up inside the awning arm and plugs into the light string at the end of the tube. Works great.
  • I have the same lights but luckily haven't had too many inquiries about them. They have double-sided tape to attach but it isn't very strong. I run my power cord, receiver and power adapter down the awning channel.
    The first set I got had a bad receiver and they always seem to stick to the awning when it is rolled up. I also have a few lights that don't work on certain colors....cool lights but sketchy quality.
  • So how are the lights mounted and how do you route the power cord so its not waving in the wind?
  • gbopp wrote:
    Are you going to give us a link to the lights you used? :)
    and how did you do it? :B
  • I wish i had read your post before i bought our awning lights. We have a manual awning and after trial and much error decided to bring in the awning and take down the awning lights when we go in at night. It is much better than jumping up in the middle of the night and doing it!
  • Are you going to give us a link to the lights you used? :)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,387 PostsLatest Activity: Aug 16, 2025
