M.A.Taylor wrote:
The manual for my Winnebago Sightseer 35N gives a range of load for RV AC units. It says they draw 1400 to 2000 watts at 13 to 19 amps. Why would a 3000 watt, with a 6000 watt surge capacity, converter not run it?
The problem is not necessarily with your Inverter. The power does not originate in the Inverter ... it comes from your batteries. For the sake of this discussion, let's say your AC only draws about 1500 Watts. ( You had better hope so! ) That will convert to about a 150 Amp draw off your battery bank. If you have four standard GC2 type Golf cart batteries such as the Interstate U2200, that is a 440AH battery bank. You do know, don't you, that repeatedly drawing your battery bank down below the 50% level will significantly reduce the life span of your batteries? ( Read - more $$ ). Now another big "IF" .... if your solar system is producing at max gain, which will likely be about 30A in your case, then you can substract that 30A from the 150A draw from your batteries .... leaving 120Amp draw from them. If you stick with strong recommendations of not drawing down your batteries below their 50% capacity, then you will have a bit less than two hours of Air Conditioning on a hot day before endangering your batteries.
Add to this I have not addressed what else your RV is drawing from the batteries..... refrigerator control circuitry is significant.... all the other little things that draw power .... entertainment...
Do you get the picture, now.
And further you have not addressed whether or not your Inverter is a MSW Inverter or a True Sine wave inverter. You may likely destroy your AC compressor motor if running on MSW Inverter.
