64thunderbolt wrote:
My bath door is 1 1/4 and the kwickset wouldn't tighten up on it. The thickness is the issue. Kwickset also sells the mobile home bolt assembly seperate to use in your existing door. Works with a reg lockset. I used those on my Mfg home, a rental that I have. And I am old so those other stores don't have all of us. LOL.
Do you own a hack saw? That and a file are all I used to make on ordinary low cost KwickSet assembly work on my bathroom 1-1/4" door. Just take a little off the half-round shaft to make it fit. On a locking set, there'll be an inner lock rod as well, that may also need trimming.
