Cummins12V98
Jul 21, 2014Explorer III
Bill.Satellite wrote:
There is no park that would care whether you used or did not use an autoformer. As mentioned above, the autoformer draws additional amps and turns them into volts. It WILL bring lower voltage to higher numbers at the expense of total amps available. This is usually not any kind of an issue as we generally don't max out our amps but it can be if you are trying to run A/C plus other accessories on a 30 amp circuit. So now if you had 30 amps available without this unit you might only only have 20-25 amps left over.
Look at my post just above. I said they did not allow them. That is a fact! Now they do that is a fact also!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 16, 2026
