Gillkid's avatar
Gillkid
Manual stabilizer jacks with a drill
I had an extra cordless drill laying around here and thought I'd put it in the TT. I also took the bit out of my socket set thinking I could just use that to move the stabilizer jacks. I soon realized that I had no way to mount the bit onto the drill. Any thoughts or suggestions? I realize that I could just cut the bit off the handle that came with the TT, but I thought I'd try to make this work before damaging the handle. If any of you guys have done that with no problems, I suppose I'll do the same.
  • BobsYourUncle wrote:
    You can get an adapter that goes into the drill and takes a socket, but they are fairly light duty and could break if you torqued on it with a socket that size.
    Just make sure that your jacks are lubricated and move freely, and you shouldn't have any problems. I've been using mine for years.
  • Any hardware store will have a socket adaptor for a drill, then buy the appropriate sized socket. I bought my socket and adaptor together from a local RV store.
  • Never seen the drill adapters before. I just ordered some. They're fairly cheap, so if I break a few, that'll be fine. Thanks for responding.
  • You can get an adapter that goes into the drill and takes a socket, but they are fairly light duty and could break if you torqued on it with a socket that size.
    I had a spare crank so I just cut one off and ground 3 flats into the shank so the drill chuck would hold. Works like a charm and I can run my jacks up and down in a very short time.
    I have never even once used the handle since then, always the drill
  • I bought an adapter that fits into the chuck and allows you to attach your sockets. I've seen them at many tool stores.
