- RE_ToddExplorerYour standard vent cover is not designed to stay open going down the road. That's why I have the Fantastic covers so I can leave them open all the time!
- BarneySNomadDusty,
I had one of those on our previous trailer. We loved it! It moved a ton of air and was very quiet which was great as it was in our bedroom.
They no longer make that model as far as I know so I would suggest searching for TurboMaxx on many RV supply sites and perhaps you could fine someone who still has it in stock.
Found a place!
Don't know if the ad is still good but would be worth a call! It says it is in stock and free shipping to boot! :)
Good luck!
Barney
Edit: Here is another one.I think this one is without the thermostat but still 3 speed. - Dusty_RExplorer
BarneyS wrote:
Fire Instructor wrote:
I installed a MaxAir cover over my automatic FantasticFan, and had to take it off. The lid on the fantastic fan hit the underside of the MaxAir dome and wouldn't allow it to completely open. Since it wouldn't completely open, the limit switch on the fan wouldn't allow the fan to run. Removed the MaxAir dome and replaced it with a FantasticFan dome, and it works fine.
That is strange. I have two Fantastic Fans with the Model 800 Fan Mate covers and the fans work perfectly. Yes, the lids do hit the underside of the MaxAir dome but the fans work just fine. They open and close just as they were designed to do. On mine, the motor starts/stops running just as the fan lid leaves/reaches the bottom and is ready to seal. Perhaps your limit switch is positioned a bit differently than mine.
Barney
Here is the one I have(bottom one).
We had one like pictured, in our old mh that we traded in, but the fan and motor was at the outlet of the hood. Anyone know where we can get one like that.
Dusty- bobbinzExplorer
I have just the cover part shown in bottom picture id like to sell it if ya think anyone would like to buy it do you think it would be usable for anyone it in great shape
- BarneySNomadYes the lid stops moving when it hits the top of the cover but the fan continues to run. I like those new ones that you can open. I have to take mine off everytime I want to clean under it.
Barney - IAMICHABODExplorer IIIThe new Maxx Air Fan Mate 955 like this is taller and I have no problem with my Fantastic Fan,which BTW the cover is designed to stop when it hits anything. I like the clips,they make it easy to open and clean the vent cover.
955 Maxx Air - BarneySNomad
Barney
- bobbinzExplorer
So the one pictured on bottom with round vent 2 bars I have just cover do you know if ya think anyone would purchase just cover part and what I should ask for it if I could even sell it
- way2rollTrailblazer
You won't get a response from Barney. Mainly because you're responding to a topic that's 9 years old, Barney hasn't been on here in years, and per the rules you can't sell anything on this forum. If you want to sell your cover, try Craigslist or FB marketplace.
- Fire_InstructorExplorerI installed a MaxAir cover over my automatic FantasticFan, and had to take it off. The lid on the fantastic fan hit the underside of the MaxAir dome and wouldn't allow it to completely open. Since it wouldn't completely open, the limit switch on the fan wouldn't allow the fan to run. Removed the MaxAir dome and replaced it with a FantasticFan dome, and it works fine.
- StraboExplorer
rexlion wrote:
They are great. I could keep the vent open 24/7 while the trailer was stored in the back yard, so there was always some air movement. And while driving I could have it open, too; don't try that with an unprotected vent cranked open or you could break off the lid.
I first put one on when my vent lid decayed from UV exposure (after about 4 years). A cracking lid that goes undetected could leak into the trailer, but a vent cover helps protect the trailer from potential leaks while it prolongs the life of the lid.
X2 - whitExplorerMy coach gets hot in the summer when stored. It's nice to let out some of that heat and get fresh air in. Especially with the cover on!
- 93Cobra2771Explorer
SkiingSixPack wrote:
They do not screw into the roof, there is a bolt that gets drilled horizontally into the frame of the existing vent. They work great.
Unfortunately, there are some installers (both back yard and rv service) that will install them straight into the roof material, and then dicor over the screwheads.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
