milo's avatar
milo
Explorer II
Oct 20, 2014
Minor Step Modification
We have a 2014 Cougar 26sab that has been just a fantastic 5er. Only complaint we've (DW) has had with it was the steps leading up to the bedroom. There is/was 2 steps each bout 9 1/2" high. DW decided that was not going to cut it so she instructed me to modify em into a 3 step setup. The problem with adding a 3rd step was ...1, the pantry door opened over the first step & 2ndly the louver opening for the furnace was right in front of the first step. So adding a 3rd step to make em a different height, presented a challenge in design. This is what I came up with: Each step is 6 1/2 inches high, both bottom & middle platforms are removable. Middle platform so the pantry can be opened & bottom platform so slide can fully close. Minor inconveniences. Complete build cost me a little under 50 bucks. Only had to buy the plywood. Frame is 1/2" Birch plywood I stained dark cherry to match cabinets, platforms are also 1/2" plywood w/cherry laminate flooring (from S&B job) glued on top. 2 screws hold the frame to the steps & complete setup can be removed if need be.
This pic is of the original steps
The next 4 pics are the progression from start to finished product.
Neat thing about this is they cover the existing steps so no dismantling the old steps was necessary.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
