agesilaus
Sep 12, 2016Explorer III
Can't you run a power extension cable to the facility that you are working at? Tho that may be questionable depending on how many amps the a/c and/or the heater draw. For quiet power, a 4K Honda or Yamaha generator would work but would need to be in a vented compartment. And you'd have to make sure you drain the fuel out of the carburettor when you put the bus away. Any reasonable sized battery set would probably be flatlined by the a/c or the heater.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
