time2roll
Sep 12, 2016Nomad
If you plan to run the air or a space heater without plugging in you really need a generator. A Honda EU3000i is what you need. If lifting over 100 pounds seems a bit much then consider two Honda EU2000i in parallel. Possibly an extended run fuel tank if you will have long days needing air conditioning.
Parallel Honda $2100
Extended run tank $200 (amazon)
If you prefer to get by on one honda you would need a smaller air conditioner of maybe 9000 BTU max. Could be marginal for the older set.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
