- C_SchomerExplorerMy wife is short and I've put pull switches on the ceiling lights in all of our RVs. I use fan pull switches - 2 or 3 speed depending on how many bulbs. That's the cheapest and easiest. I cut the strings so my head doesn't hit them and wifey can reach them. Craig
- BobboExplorer III
Poppy & Nana wrote:
Thank you one and all.....I'm not keen on the remote, that is why I was looking at the pull string.
I would love to have two wall switches, since we have two doors into the bedroom (his & hers).....however there is no place to pull the wires down to the switch. The bedroom wall is all wood and the back of the entertainment system....if anyone has any other suggestions, I would love to hear them!
That was why I suggested surface channel to wall switch.
http://www.homedepot.com/b/N-5yc1v/Ntk-Extended/Ntt-surface%252Bchannel?browsestoreoption=1 - TurnThePageExplorerLooks like that device might be capable of powering the water pump too. Might try that!
- FlatBrokeExplorer II
Artum Snowbird wrote:
Have a look at these
Remote switch
Great idea. I have the bath fan over the shower. Would be nice to be able to turn it while sitting on the throne. Will work for That? - Poppy___NanaExplorerThank you one and all.....I'm not keen on the remote, that is why I was looking at the pull string.
I would love to have two wall switches, since we have two doors into the bedroom (his & hers).....however there is no place to pull the wires down to the switch. The bedroom wall is all wood and the back of the entertainment system....if anyone has any other suggestions, I would love to hear them! - DonConExplorerWe installed a wall switch also. One of the best mods made.
- tenbearExplorerWe have a hard to reach bedroom light too. I found the wires to it and installed a wall switch
- westendExplorerI haven't done it because I dislike strings hanging down but it would be easy to do. Usually, with a double bulb RV fixture, there is a dividing strip of plastic between the two lenses. That strip may house the original switch and it may not. Regardless, you want to mount the pull switch in some part of the fixture housing. If you have the plastic center divider and the original switch is there, that's an ideal location for the new pull switch. Drill the correct sized hole in the fixture and mount the switch.
Your existing fixture and switch will have two wires into the switch. Remove or cut one of those wires. Splice the two cut ends or add another wire to the new switch so that your new pull switch is between the original switch and the removed/cut wire. Replace fixture into location, you're done. - ADAD437ExplorerLooks pretty straight forward to me. It looks like you will have to turn the light on the setting you want and leave it then turn it on and off with the remote.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 15, 2026
