wgp's avatar
wgp
Mounting a television
Planning to mount a flat-screen TV in my Jayco trailer. There is a panel provided for this but I suspect it's not very thick (3/4" at best?) and thus heavy-duty screws likely are out (there's a mirror on the flip side). Suggestions?
  • can the mirror be removed, at least until it is fastened. I wouldn't do it with only screws unless you are willing to take the TV off the bracket every time you are going to move the rV. use bolts and if necessary put spacers between the mirror and the wall. at any rate, I would put that extra 3/4 inch piece of plywood on the mirror side.
    bumpy
  • With the new light weight TV's you are probably okay placing 4 wood screws through the bracket. I had no problem with mine.
  • Possibly attach a piece of 3/4" plywood to existing piece of 3/4"? This would give you a 1-1/2" thickness. Use 1-1/4" screws and Tightbond II or III glue.
    Bill
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Oct 12, 2025
