pmfinnegan2's avatar
pmfinnegan2
Television mount???
We are going to be getting a new TT soon. The one we are interested comes with the entertainment center that swivels 360 degrees so you can view the television in the living or bed rooms. We already have a flat panel television we will be using, but I will need to buy a mount to install it in the TT. What kind of mount do I need to get to install it in the swivel entertainment center?
I wouldn't mind getting one where I can pull out the television from the entertainment center on the television mount, but not sure if that is an option.
Suggestions? And where to purchase?
  • I installed this mount from Amazon ($17) into the revolving entertainment center like yours. It pulls out to easily access behind the tv, yet also lays flat. All the pivot points can be tightened with the provided allen-wrench so there is no chance of moving while traveling.
  • pmfinnegan2 wrote:
    So I can buy any Television mount? It doesn't have to be RV specific?
    Nope - my RV TV is hanging on a general use mount. Works great and cost me all of 16 dollars on Amazon
  • You've got most of what you want with the 360 swivel.
    We don't have the 360 swivel so only TV in the main room. We got tired of watching TV at an angle with the basic mount that came with it. Here's the mount we installed: MOR / Ryde Mount
    The best part is that the TV stays in place because of the locking feature (won't pop out on you as you drive)
  • So I can buy any Television mount? It doesn't have to be RV specific?
  • My RV has the swivel TV feature like you mention. I bought this mount from Amazon to mount our TV. I like it because it lays almost flat so I can keep the TV in the recess designed for it in the entertainment center, but I can also pull it out to access the back if I need to. It works well.
    I see that particular item is no longer available but any similar articulating mount should work.
  • Check out Amazon....search TV Mount...Amazon should keep you busy......
