gjcummings
May 24, 2015Explorer
Speaking from experience...Get any size mirror, unframed is best, to fit the door and get Loctite PL520 for Mirrors. It is like a caulk and you need a caulk gun and you need to take the door off and lay flat and put some heavy object on the mirror and let set overnight. If you ever want the mirror to come off I would nor use this method.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
