Wrace's avatar
Wrace
Mounting mirror on bathroom door.
Our tt has the hollow core bathroom door that is typically installed on the entry level trailers, and I would like to mount a longish mirror on said door.
Given the very thin door material I'm wondering what the best way to do this would be?
The door mirrors in our house are mounted with mirror clips but these are larger heavier mirrors than I need for the TT (I think).
I'm thinking something along this maybe? Or other suggestions are welcome. Although it's only 13" wide. I think this one may be pre-drilled
http://www.homedepot.com/p/Glacier-Bay-Suave-49-in-x-13-in-Framed-Door-Mirror-in-White-206230/202300822
Or maybe this one though it's larger and heavier and I would assume require clips.
http://www.homedepot.com/p/Glacier-Bay-60-in-L-x-16-in-W-Beveled-Door-Mirror-205220/202300824?MERCH=REC-_-PIPHorizontal1_rr-_-205585950-_-202300824-_-N#BVQAWidgetID
What type of fasteners should be used on these hollow core doors?
Thanks
  • Use these (with mirror clips and screws):
    http://www.mrgrabbar.com/TOGGLER-Hollow-Wall-Anchors-TA-Thin-Panel-p/11009.htm
    Clicky
    My Bathroom door full-length mirror and the full width heavy mirror at the bed-head were installed with these and they have not moved in 8 years of travel.
  • Scotch or 3M double sided mounting tape..
    Comes in different holding strengths.
    Home Depot - Lowes, etc.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
