4x4van's avatar
4x4van
Explorer III
Sep 05, 2013
My experience with LEDs (warning: long, but lots of info)
I dry camp alot, so the LED threads have kept my interest for some time. My Class C has a very open layout, which means lots of space to illuminate, and unfortunately that means lots of lights/fixtures. My interior lighting consisted of 7 double bulb fixtures and 4 single bulb fixtures, all using #1141 BA15s bulbs (measured current: 1.41A @ 12.6VDC) and having opaque lenses. Of course there are also a few additional bulbs; porch light & step light, stove hood light, wall sconce, etc. With that much space and that many bulbs, it’s easy to get the imaginary meter spinning, yet I was never really happy with the illumination provided. So my goal was not just LESS current, but MORE light as well. That seemed to be a tall order. But with the prices on LEDs decreasing and the variety and styles increasing, now was the time to try.
Now, personally, I dislike the yellowish “warm white” that many seem to prefer (both in LEDs and incandescents). Especially with an older MH like mine, they just seem dim and dingy to me. But I similarly dislike the cold bluish tint of the “cool white” LEDs. What I was looking for was something in the middle, something that mimics the daylight sun, with true color rendering, and lots of it. I learned that what I was looking for is about the 5000K–6000K temperature range; any higher starts to look blue, lower starts looking yellow. This “middle of the road” color is sometimes referred to as “pure white” or “bright white”, and as a plus it puts out more lumens and actually “looks” brighter than either the warm or cool colors. But you have to be careful; unless the actual color temp (in Kelvin (K)) is listed by the distributor, you can’t be sure what actual color you’re getting.
I started with outdoor lighting. I was using a 120VAC rope light hanging from hooks on the awning roller, but it was really more of yellowish “accent” lighting than anything else, and of course could only be used with the genset or hookups. There was also the hassle of putting it up and taking it down every trip, or if the wind came up. Surely today’s LED technology would allow me to do better. So I purchased a 5 meter (16.4’) LED strip light, containing 300 LEDs. These strips are 12VDC, thin, flexible, waterproof (the one I bought is inside a robust silicone rectangular tube), and can be cut to length (more on that later). The 5 meter length was perfect for my application; it is glued (silicone) to the awning roller and rolls up inside. No hanging or installation/removal necessary; once the awning is unrolled, I simply plug it in, and my entire campsite area under the awning is brightly illuminated. Measured current: just 0.91A @ 12.6VDC. It was such an unqualified success, that I decided to jump in with both feet. I read everything I could on these and other forums and websites, and then I bought a few of these, a few of those, tried them here, tried them there...and here’s what I ended up with (and why):
-All ceiling fixtures in the main living area as well as the bathroom, entry, and closet got the(flat) panel style LEDs in the 48-5050 configuration (I first tried the 48-3528 panels, but wasn’t satisfied with the light output). The 48-5050s put out a similar amount of light to the 1141 bulbs they replaced, at only 1/4 the current. Measured current:0.37A @ 12.6VDC (74% less than the 1141 incandescent).
-In the overhead bunk, I used the 48-3528 panels (first ones purchased, originally intended for the living area. While they were deemed insufficient (IMO) for that larger area, they work fine for the smaller bunk area). Measured current: 0.21A (86% savings).
-For the 4 under cabinet 2-bulb fixtures (couch, chairs, dinette, kitchen), I chose a different route entirely. Here, I purchased another (5 meter) LED strip light, this one with 600 high output LEDs. I cut it into 4 sections of just over 4’ each, and attached them under the front edge of the cabinets with silicone, installing a rocker switch for each and removing the 2- bulb fixtures in those locations entirely. IMO, this is what makes the whole setup work so well. The light output is nothing short of amazing, yet the measured current of each 4’ section is just 0.78A (72% savings over the 2-bulb fixture each replaces).
-Porch light: First I tried a 36-5050 panel in the porch light, but it’s “eye-level” location (porch light/grab handle combo) blinded you as you approached the door! So instead I went with a 13-5050 “bulb style” replacement. It’s still quite bright when approaching, but bearable, and still produces a usable amount of light. I may still change this out to a yellow/amber one later as a “bug” light. Measured current: 0.28A (45% savings over the #89 bulb it replaced).
-The interior step light (tied into the porch light circuit) got a small green 5-5050 bulb style. Measured current: 0.05A (55% savings over the small #53 incandescent it replaced).
-I used the 36-5050 panel (remember the porch light?) to replace the 2 wedge type bulbs (0.91A ea.) in the stove hood. Not quite as much light through the thick opaque lens, but still sufficient. I may swap this out for a brighter 48-5050 in the future. Measured current: 0.2A (89% savings).
-Finally, although it doesn't run off the house batteries, I replaced my #57 incandescent dome light in the cab with a white 5-5050 bulb style. Measured current: 0.05A (79% savings).
Overall current savings? IF EVERY LIGHT in my RV were now used all at once; the ceiling, under cabinets, o/h bunk, bathroom, entry, closet, stove hood, porch/step lights (25 lights!)… the current is equivalent to just 5 of the original 1141 bulbs (2 ½ fixtures)! And the illumination would literally drive you from the RV and/or blind you! More light AND less current? Mission accomplished on both counts.
A more typical evening use, inside & out, would look something like this:
Old incandescents: Couch fixture, dinette fixture, 1 ceiling fixture, porchlight = 9A
New LEDs: Couch strip, dinette strip, 1 ceiling fixture, awning strip =3A (with significantly more illumination, especially outside).
And what did I spend? Using Amazon and eBay, the 300 LED strip for the awning was $22, the panels (48-3528, 48-5050, 36-5050) were all about $4 - $5 each, the 13-5050 and green 5-5050 bulb styles were about $2 each, and the 600 LED strip was $33 (all prices include shipping). Add in 4 small rocker switches @ $2.50 each for the under cabinet strips, and the grand total was less than $125.
  • 4x4,
    Very well written disposition. I have a similar Jamboree and have been holding off going this route but now I am inspired. I was curious what you did with the holes left from the removed lamps. Is this where you installed the switches? Also where do you plug in the awning lights? Do you have an external 12V outlet?
  • I buy LED's all the time on Ebay .. I buy the type that come on a roll and if you watch you can pick them up pretty cheap. I just bought 300 on a roll of the bright white. they come with 3M double sided tape on the back you can even get them with a water prof covering. I got 300 for 4.65 with free shipping. Now how they can do it beats the heck out of me but I've bought about 5 rolls in the last year or so and you can even get them where they change colors or blues, reds or lots of other colors. Just watch the price some times the same rolls I get for less then 5 dollars cost as much as 30 buck. They run on 12 volts and there are little tabs where you can solder wire and make them in any size you want even a wall wart will run several of them. I use a power supply that I have on the test bench and I can run 900 plus and I have them on a dimer so I can control how bright they get ...
    Don these LEDs are in a strip you know when you see them...
  • 4x4van's avatar
    4x4van
    Explorer III
    A few final notes:
    -LED replacements are typically called out using 2 numbers; the first is the # of SMDs (Surface Mount Diodes), the second is the SMD size. Examples; a 48-3528 contains 48 SMDs, each one measuring 3.5mm x 2.8mm. A 13-5050 contains 13 SMDs, each one 5.0mm x 5.0mm.
    -3528 SMDs each contain a single LED, while 5050 SMDs each contain 3 LEDs. Therefore, the 5050 SMD is brighter (though not 3x brighter) than the 3528, and consumes more current.
    -Layout; the bulb style layout emits light all around (360 degrees), while the flat panel type directs all the output in one general direction (usually about 120 degrees).
    -The bulb style LEDs are available in various base types, while the flat panel LEDs typically come with several base adapters (wedge, festoon, BA9s, BA15s), so make sure you know what type of base/socket you will be needing before ordering.
    -Your existing fixtures will also have an impact. Those with clear lenses seem to work better with LEDs, while the opaque lenses tend to diffuse the LED output quite a bit.
    -I suggest, as others have, ordering at least 2 each of several styles to try out first. Once you find what you like, order enough to do your whole RV, along with a couple of spares.
    -Regarding color temps; a typical incandescent is about 2700K-3500K and appears quite "yellow"; that is also know as "Warm White". "Cool White" is typically 6500K and above and will have a bluish hue to it. 4500K-5500K is neither yellow nor blue, gives the truest color rendering, and is also a bit brighter than either warm or cool, although it draws just a bit more current as well.
    -Take any "listed color temp" with a grain of salt until you have actually purchased and tried the unit. I wouldn't bet on the accuracy of any listed numbers, particularly from overseas vendors.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Dec 30, 2025
