DanKirk's avatar
DanKirk
My LED Strip Install
After seeing many new trailers at the RV Show with LED strips mounted under their awnings, we decided that we should add one to ours. I then discovered the many threads here on RV.net regarding these strips, and was thankful for the information they contained.
After much research, I determined that I wanted a waterproof strip that had both warm-white LEDs and RGB color LEDs. I also wanted an RF controller instead of an IR controller, so that I wouldn't have to mount an IR receiver in a visible location. I decided on this kit from Amazon: RGB+WW LED Strip with RF Remote
After reading the many posts here, I also ordered some 3M Auto-Body Trim tape for better adhesion to the trailer.
The kit arrived, and I hooked it up to a 12V power supply to test it out:
It looks great, and the remote is awesome. It is a touch-panel remote, that is quality built, and has a range of about 100 feet from the receiver.
I needed much more cable than the few inches that was attached to the strip, so I ordered the RBG+W, 5-conductor cable from Amazon: 5_conductor LED Cable
I also ordered 10 feet of 1/2 inch white heat-shrink tubing from ebay to cover the LED cable:
I unsoldered the short wires, and attached the long cable directly to the strip:
Then I slid the heat shrink over the cable, and shrunk it using the stove burner. I then stuck the 3M Body Trim tape to the back of the strip, and trimmed off the extra width of the tape. After that, it was ready to attach to the trailer.
  • I cleaned below the awning track with denatured alcohol, and began applying the LED strip:
    Here is the end, where you can see how the longer cable is attached to the strip and covered in heat shrink:
    It attached easily, and seemed to be very secure.
    The most difficult part was getting the cable inside the trailer. Neither end terminated where there was a cabinet inside, so I couldn't just drill a hole and run it through. I ended up running the cable to the roof, and into the refrigerator vent, and then down into the cabinet behind the microwave. I covered the cable on the roof with Eternabond to both hide and secure it.
    Once I got the cable into the trailer, through the vent, I wired up and mounted the small RF receiver and controller.
    I added a main switch to the power wire of the LED controller to prevent accidental activation while traveling.
    The lights look great! And, the controller and all wiring is hidden.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Mar 02, 2026
