mobeewan's avatar
mobeewan
Need good quality but inexpensive in line check valves
I need to fix a plumbing mod I did for the black tank. There is a plugged 1/2 NPT female connection on one end and one side of the tank. I removed the plugs and made and mounted a manifold with 2 ball valves next to the dump valves. Each valve has a hose running to a tank connection. At each connection I added a 1/2 NPT elbow with a 1/2 NPT plastic inline check valve.
What I did works pretty well for flushing and rinsing the tank. However, the check valves springs are only rated at about a half pound. When setting while camping and the black tank is being filled, there is no pressure to keep the check valves seated. This causes black tank water to seap back through the check valves and back down the hoses to the manifold. Since I originally didn't expect the check valves to leak I used PVC for the manifold and ball valves. In freezing weather a PVC fitting cracked and dripped black tank water.
The brass check valves for the water heater outlet and city water hookups are also pretty weak ruling them out for my use.
I looked for decent quality brass check valves with NPT threads and springs rated at about 5 lbs. This would be more than enough spring pressure to keep the valves seated and stop back flow from the black tank. The only ones I could find we're pretty expensive at over $50 apiece.
I am not going to replug the connections and add tank rinsers. As I indicated it works well except for the back leakage through the check valves. Better valves will solve the problem.
Does anyone know where I can find any brass inline check valves with at least 5 lb springs that are cheaper?
  • Factory installed flushing check valves are mounted higher than the top of the black tank. Is this possible for your coach?
    Richard
  • ON some RV's the check valves off the water heaters are metal ones. On my Forest River 5th wheel trailer, the 10 gallon water heater has the metal 1/2 NPT screwed right into the water heater female inlet & outlet fittings and the water lines fittings screw into them.
    Now I also have a Casita trailer with a 6 gallon water heater, and the check valves look like brass heavy duty check valves.
    NO matter what you do, which I think you've already figured out is, your going to have to get away from the plastic ones because cold weather.
    I'd start by looking on Amazon first, and then an RV parts store. Good Luck.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
