enblethen
Feb 24, 2023Nomad
The steel frame has less resistance then a #4 wire. Connect with short piece.
Verify that the bolts connecting to frame is at least 5/16, 3/8 would be better. Clean from to bare metal and use de=oxidation compound. Do same at battery connection to frame.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
