ewarnerusaNomadFeb 24, 2023Negative and ground wire questionsA spring project I have in mind is to upgrade the OEM power wire between the battery and converter to a larger gauge. I think it is currently 8 gauge and I want to upgrade to 4 gauge. The OEM setup ...Show More
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
Related ContentNegative/Ground wireBigfoot (2 negative battery ground wires???)Is one of your tie down tabs grounded?Open Ground questionOpen Ground
