lenr
Feb 24, 2023Explorer III
Do both. Technically there should be only 1 frame connection, but I've had no problem running a new negative battery to converter wire when the trailer already has 2 frame connections for negative return. I'm concerned about corrosion at frame which is often out in the weather.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
