Bobbo
Feb 24, 2023Explorer III
Wire to the frame is enough. Running a separate wire to the battery is belt and suspenders. Won't hurt anything though. (The wire from the converter to the battery will have more voltage drop than the wire from the frame to the converter. Using both reduces voltage drop even more.)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
