larry_cad
Feb 25, 2023Explorer II
If you use the chassis as a conductor, you have 4 connections, two at each end. If you use #4 wire, you have 2 connections. Reliability in electricity is a function of the number of connections. 2 is twice as reliable as 4.
If you decide to use the chassis anyway, be certain to use a corrosion limiter such as De-Ox, or similar. Once the connection to the chassis gets rusty, you are in line to have the next problem.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
