lj2654's avatar
lj2654
Norcold High Temp Sensor Box
Well, I learned today that if your Recall black box gets a flashing red light it most likely is the high temp sensor that is attached to the heat tubes with a wire going to the black box. I though...
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Oct 12, 2025
