Just_There's avatar
Just_There
High AC voltage - Norcold Fridge
Can anyone tell me what the result of high AC voltage would be for our Propane/120v Norcold Fridge? The shore power fluctuates, sometime as high as 133v. The rest of my rig is on the EMS which switches me to batteries/inverter over 131v. I took the fridge off that circuit because power failures are not uncommon and the fridge would take my batteries down fast, On a separate circuit a power failure will switch it to gas, but it is running without the EMS protection. Is the high voltage damaging the fridge? How high is too high?
  • Norcold AC Requirements.......... 108VAC - 132VAC
    *DC ... 10.5VDC - 15.4VDC
    Dometic AC Requirements.......... 100VAC - 132VAC
    *DC .... 9.6VDC - 22VDC
    DC Voltage would be more of a concern then the AC Voltage
  • Onan gas gensets the no load voltage range is usually 128 to 132 volts. So, I would not worry about 133 volts. The good thing about 133 volts is, it will make your refer operate better on 120 volts. The higher the line volts on AC the more heat output the Norcold refer element puts out. You really need to get a surge/line voltage device for your shore cord. The Norcold would be the LAST item of 120 appliances in my RV I would worry about 133 volts. Doug
  • Look on the name plate of the fridge. If it says 115 volts, then 133 is pushing your luck. If it says 120 volts, then you are one volt over.
    I'd check the voltage at the fridge, and hope for a little bit of voltage drop.
    There are buck converters available.
    Another solution is a Sola Basic Autoformer.
    Consider putting the fridge behind the EMS. Then add a 10 amp battery charger directly to the "house batteries", plugged into the shore power.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
