sjturbo
Aug 07, 2014Explorer
To clarify, I was not looking for advice in the video. It was just the 285 watt panel that caught my ear. I watch most video's with some skepticism. I realize that some people may be more knowledgeable than others whether in videos or in forums. My purpose is to investigate various options that people use. Apparently the higher wattage panels are higher voltage also, (I did not know this until I started surfing the various RV and solar forums). Higher wattage panels are interesting because I could use less. I also realize that they take up more real estate. If I were to go with a high voltage panel I would also use a MPPT to get the highest efficiency possible. I had not intended to create a 48v battery bank or use a 48v inverter. I do appreciate everyone that takes the time to read and reply my posts.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,403 PostsLatest Activity: Apr 09, 2026
