Several years ago someone had posted drawing and a little project box for 30A twist lock generator plug to 50A RV plug with metering and on/off switch so you didnt have to start the generator under lo...
I can't help you with your search, but the way I keep from starting my generator under load is to not plug the trailer into the generator until the generator is already running. Alternatively, turn off the main breaker in the RV breaker panel until the generator is running.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
