SuperDuty6_0's avatar
SuperDuty6_0
Question about leveling trailer
New to forum...hoping someone can answer my questions. So, I just completed a spring over axle conversion on my fifth wheel (converted to gooseneck) and wondering if I can move one end of each leaf spring, higher up into the hanger, by drilling new holes. I realize that would only lower the trailer one half of the distance...I plan on moving the holes 1 3/4" higher, effectively lowering the trailer 7/8". Will this have any adverse consequences? I can't mover the center shackle up any higher. I'm scared of screwing something up. Lol. Thanks for any insight.
  • BarneyS wrote:
    I am not a tire engineer or any kind of engineer but I do know that the ends of the springs work in concert with each other and the hight of the ends relationship with each other has an effect on how the wheels act - something to do with "rake and trail" or something like that. I would check with a frame shop or trailer builder to find out before making any kind of change like you propose.
    Barney
    Something to think about. Thanks for that. More than likely, I will leave things the way they are.
  • Lengthen the gooseneck the appropriate amount. Be sure to load the trailer and truck prior to taking your measurements. The shackle brackets have a 2 or 2.5" pipe welded between the flats for stiffening that will interfere with your plan.
  • I am not a tire engineer or any kind of engineer but I do know that the ends of the springs work in concert with each other and the hight of the ends relationship with each other has an effect on how the wheels act - something to do with "rake and trail" or something like that. I would check with a frame shop or trailer builder to find out before making any kind of change like you propose.
    Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
