Tricon
Mar 30, 2017Explorer
hedge wrote:2oldman wrote:
I just installed the Victron unit (which is amazing since it's bluetooth to your smartphone) and it also required installation of a shunt as you pictured above.
I have the Victron with the BT dongle as well, I't's great being able to check it with your phone from outside or within quite a ways of the camper instead of having to go look at the meter. My meter is hidden away in a cabinet
Hmm, my inverter and other loads are quite a bit away from where my charge controller is. If I hook it up at the controller, it should still give me battery and solar charging stats correct, it just won't know the status of any other part of the system? If so, I'm ok with that.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
