2oldman
Mar 30, 2017Explorer II
Tricon wrote:
a) my inverter and other loads are quite a bit away from where my charge controller is. b) If I hook it up at the controller, it should still give me battery and solar charging stats correct,c) it just won't know the status of any other part of the system? If so, I'm ok with that.
a) I don't know what that has to do with installing a shunt at the batteries
b) it will give you amps into the battery when the solar is working, but won't tell you anything about amps out of the battery, like at night. It may tell you the battery voltage. I'm not sure.
c) Nope. You're kind of defeating the purpose of the unit by not installing it properly.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
