MrWizard
Mar 31, 2017Moderator
The shunt is on the sensor transmitter
That part has to be mounted at the battery
Has nothing to do solar controller
Is going to monitor what goes in & out of the batteries
It has to be mounted and wired at the batteries
Attach main shunt heavy connection to battery neg , ground cable on the other heavy stud
Then run the power wire to the positive post of battery
Load is the whole RV
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
