Poncherelly
Jul 13, 2014Explorer
Can anyone provide some guidance on my install? The seelevel has 1 wire for the pump and heater but the heater and pump have 2 wires with the switch completing the circuit. Do I simply connect the down stream line (no power when off) to the see level and the units will get their power from the seelevel panel? If this is the case, what have others done with that extra 12volt wire? I figured one will be used to power the seelevel. Am I understanding what needs to be done?
Oh and my heater reset switch also has 2 wires and only gets power when the pump is on, which wire do I use for that light?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 23, 2025
