garyemunson's avatar
garyemunson
Explorer II
Mar 22, 2017
Tire Pressure Monitor Systems
After seeing another post asking about TPMS I felt compelled to jump back up on my soapbox. A friend of mine recently avoided disaster when a quite new front tire blew on his Class A putting him in the median. This happens too often and most times the tire is so shredded that a cause can't really be determined and it is just written off as tire failure. My feeling is this is most likely an issue of low pressure caused by some sort of road hazard. Most of your driving in your car is less than an hour duration and picking up a nail just results in a slow leak that becomes obvious when you come back out of the store/work/school and find a flat tire. RVs are generally driven for longer stretches of time and if you collect a nail, the tire has plenty of time to leak down to the danger level and it's also likely that you are driving at highway speed that will cook the underinflated tire and cause a blowout at speed. THAT'S why i would like to implore EVERYONE to install a TPMS!
