MrEven's avatar
MrEven
Rebuilding a Class C Jamboree, have many questions
Brand new here so please forgive me if this is the wrong place to post in these forums.
I am new here and new to RVs, but I've worked as an automotive technician for some time and am comfortable with the mechanical workings. I picked up a 1984 Jamboree for under $400 because it's suffered from very extensive water damage. I am planning on gutting everything and doing a rebuild. I have a few questions I hope you might all be able to help with:
1) What size wood should I use for the wall studs, roof trusses, and floor joists? (2x4, 1x3, etc)
2) Is there a preference of one type of wood versus another? (Azdel vs luan vs pressure treated, etc)
3) Once new studs and roof trusses are placed what sort of epoxy/glue/etc should I use to bond them to the exterior wall? I've seen some people recommend Liquid Nails or 3M boating composite but I want to make sure I use the right material. I believe the exterior wall is fiberglass/laminate.
4) Can I use closed cell spray foam insulation? I've read some people say it will crumble apart while driving and others say it holds just fine. The very high R-value makes me want to use closed cell but if it crumbles apart then it's not a real option.
5) Should I rerun all wires/cables current found in the walls?
6) Is regular plywood or particle board ok to place over the studs and insulation or is something else recommended? Is Azdel the wood-of-choice?
I know this is a lot of work and I'm excited to do it. I look forward to your suggestions. Thank you.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,382 PostsLatest Activity: Jul 26, 2025
