2000_Kiwi's avatar
2000_Kiwi
Refer Vent Blockage
Ok, so I know there have been hundreds of vent fan installations posted here... But even if you don't plan on, or don't want to install a vent fan, you may want to check for airflow obstructions.
I know the southeastern summer is going to be a hot one and I wanted to make sure my refrigerator is running as efficiently as possible.
I went to install a vent fan, when I pulled off the roof vent cover I noticed the rubber roof was blocking much of the airflow.
So... I cut back the rubber roof a few inches... To my amazement I found that the wall insulation on both sides had fallen over on to the refrigerator fins. In the photo below I had already cleared the insulation from the right side.
In short, you may want to check for any obstructions that may limit the airflow behind your refrigerator.
Power was easy to locate...
Vent cover sealed with Eternabond tape.
Fan installation looking from the roof vent down behind the refrigerator.
Fan installation looking from the bottom vent up to the roof vent behind the refrigerator.
Unfortunately I don't have any before and after airflow or temperature specs but I know just removing the obstructions will be an improvement!
  • Wow. Thanks for posting this. I'll be checking this as soon as I get the trailer out of storage. My trailer came with a vent fan in the exhaust stack and it always seemed to me that the fan runs quite a bit. This can be a significant power draw when boondocking, but I thought it must have to be that way. I never thought of looking down the stack to check for blockages.
  • Nice work.
    Mine was in a similar condition especially the roof vent.
    After fine tuning my installation it can be well into tripple digits and has no problem working on electric.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 29, 2025
