don_a's avatar
don_a
Renovating shower to take advantage of fully avail space
Hi, I have a 84' Itasca by Winnebago (ICR27RU) and it's one of those things that I have invested so much money into over the years, basically I am still driving it and it's still doing it's thing so to speak so why change, especially with gas (temporarily) so cheap. At the moment I am thinking about taking on a long journey South and when I say South, well very South ....
One thing that I have always been unhappy with in this unit is the shower. From what I have learned over the years, Winnie put a shower shell into this model that is not too tall at all. In fact the shower stall was built for one of there smaller motor homes but from what I recall from talking to a Winnie engineer years ago, he said they put that same shower shell in several models, regardless of the size of the space that could be used, using one small enough to fit all models for that year. Now at the moment I don't have photos to show what I am talking about but the shower is the style of a mini squat-tub with stopper and straight walls up to a point but they all start to come in on you at the top, giving not too much head room. (An actual much larger stall could be used because the space behind the plastic walls is there, they just cut cost by using the same shower everywhere that year.)
What I'd like to do is rip the top half of this shower stall out and place some material on the 3 square walls to take advantage of the full space that shower could occupy, getting rid of the smaller pre-fab shell which is designed to severely narrow at the top.
Now this has me wondering if this is practical and should I use some type of heat malleable material that I could stuff and wrap into the 3 sided shower stall once I removed the top part of the existing shell. It would really be nice for me to be able to stand up in the shower and not bang my lip or nose on the shower head.
Considerations on why not to do this include comments I have seen on some PanAmerican Travelers forums discussing roads that literally tear you shelves off the wall. I don't want something that is going to fly all to pieces on the first bumpy road I hit but I really hate taking a shower in there while having to squat (I know, 1st world problem but please let me complain just this once LOL.)
Additionally:
I'd also be interested from those who have experience with this type of rig or doing this sort of thing, to learn ways to make the cabinets and doors stay closed in this model. The conventional latch is hard to adjust and with each trip things shift to the point they have to constantly have to be readjusted.
Thanks in advance for any advice.
  • I feel your pain! I have a 2003 Sunova and the shower is just big enough. You have to "plan" how you're going to reach down and wash your foot! Mine is built up off the floor about 6 inches. I've got room for a larger shower but it would be a good bit of work and you'd have to think about how you're going to get a "one Piece" shower in the door. Might have to come in through the windshield and then you still have to get it back the hall so I'd say a "one piece" is not an option. I'm going to live with mine. As I get older I'm starting to weight in the "work factor" when I think about "mods" more than I used to. With a 6 gallon water heater, in a part time home, I really don't spend a lot of my life in there.
  • Thanks for the reply. The motorhome is currently stored a good distance away. I am in the process of wrapping up a home remodel and sell, and will be focusing on this in the next couple of months. I'll get more details hopefully at the end of the month when I have time to head out to my storage locationand do a survey. I'll provide an update then. Thanks!
  • Do you have any photos you can post? I'm assuming the enclosure is plastic and if that's the case you may be able to heat and reshape it, but it'll likely be ugly.
    I'd be a little weary of using individual sheets for the enclosure instead of a 1 piece surround with all the movement. Do you know if the pan extends to the walls or will you still need to pack it out to install new walls? You may still be losing some space if it doesn't.
    Have you looked at any replacement pans and surrounds that may be a better fit? Do you know the dimensions of the space you're working with?
    I'm thinking about doing a custom gelcoat fiberglass wet bath enclosure in our new project trailer, but haven't decided on that yet.
  • I have a much more modern rig a 94 Toyota. The shower is just adequate and no extra space to expand.
    If you have the space and inclination, go for it! Some of the plastic panels are formable with heat, a daunting task for someone that has not done it, but doable. You may screw up the first panel or 2 but oh well.
    Another option is to build what you want with plywood and cover it with fiberglass, I am not sure about the fiberglass bonding to the material that is already there, so look that one up.
    I have seen entire showers built in an RV with plywood and fiberglass, then you can go right over it with tile if weight is not an issue.
    Make sure there is a shower available, may take a bit longer than you think! Jim
    ps Don't use silicone for anything, if silicon is the answer you are asking the wrong question!
  • Wow an 84 foot long Itasca and I thought my rig was fun to turn corners with. I think what you want to do to your shower space should work great, what could possibly go wrong.
    The information is out there, all you have to do is let it in.
